Perform the following procedure to display the RSTP-related configuration information for the selected port.
Display the RSTP information for a selected port:
Switch:1# show spanning-tree
rstp port statistics 1/4
======================================================================== RSTP Port Statistics ======================================================================== Port Number : 1/4 Number of Fwd Transitions : 0 Rx RST BPDUs Count : 0 Rx Config BPDU Count : 0 Rx TCN BPDU Count : 0 Tx RST BPDUs Count : 9 Tx Config BPDU Count : 0 Tx TCN BPDU Count : 0 Invalid RST BPDUs Rx Count : 0 Invalid Config BPDU Rx Count : 0 Invalid TCN BPDU Rx Count : 0 Protocol Migration Count : 0
Variable definitions
Use the data in the following table to use optional parameters with the show spanning-tree rstp port statistics command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
